12745 Discussions
Shared pins on Avalon bus devices
I have a problem with SRAM chip and FLASH chip sharing tri-state address/data bus.
I have configured my custom board and ported flash programmer. I have declared FLASH chip as AM29LV641DH with designator U6 on my board. In the board Quartus design I see correct pinout for tri-state bus:
- external_memory_address,
- external_memory_data,
- ext_memory_readn,
- select_n_to_the_flash_memory,
- write_n_to_the_flash_memory.
Do not quite get it why they use a different convention of naming write and read signals, but maybe I will figure it later http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif
Now, in my system design using this previously configured board, I added tri-state bus, ext_flash memory which showed up correctly as U6, and a user logic module to my SRAM 16-bits chips on the same bus.
After nios2 cpu symbol was regenerated I got following signals:
- chipselect_to_the_SRAM_bank1 (strange anyway, was expecting chipselect_n!)
- ext_memory_bus_address
- ext_memory_bus_data,
- ext_memory_bus_readn,
- ext_memory_bus_writen,
- select_n_to_the_ext_flash,
- write_n_to_ext_flash.
What is the difference between ext_memory_bus_writen and write_n_to_ext_flash? I have this signals shared on my tri-state bus. How to configure flash chip to share commong ext_memory_bus_writen signal for its write operations?
Also, on my 16-bit bus I have two (active low) signals: low_byte and high_byte. How to configure them with "byteenablen" Avalon signals?
From an engineer...
They should declare their chipselect pin to be of type chipselect_n and read the Avalon Bus Specification Reference Manual. Page 80 of 106 talks about shared pins.
A problem report will be filed saying that the description on page 80 isn&#39;t very good. It should define the pin naming scheme. i.e.
Is_Shared = "0" yields
<pin_name>_to_the_<module_name>
Did this solve your problem?
If not reply and we&#39;ll see if we can do something.
