12748 Discussions
Simple Socket Server Application Error
When I try to build the Simple Socket Server Application on Nios IDE I'm getting the following error.
(SEVERE) generate: java.lang.IllegalStateException: java.lang.IllegalStateException: java.lang.NumberFormatException: empty String
make[1]: *** [system_description/../obj/system.h-t] Error 1
make: *** [system_project] Error 2
Pls some body help me why this error is comming?
The first step is to ensure that you have no spaces in the path to your project or to any of your installed tools. Beyond that, have you done a search of the Forum and/or Google? I'd imagine that it would yield something that bears fruit.
Cheers,
- slacker
Moving to the software section
