Socket problem when flooding
I'm having a strange issue with TCP socket.
I'm trying to write to a socket stream as fast as possible so I do something like :
c = 'a'; while(1) {  write(sock, &c, sizeof(c)); }
I use a telnet client to test my code : I get a random number of 'a', a freeze, and then the sock hangs (write return -1 with errno set to EPIPE).
I've used ethereal to investigate. The problem is the board is sending a TCP packet with a wrong checksum. This packet is send several times and then the board send a RST.
It seems to me there is something wrong with memory which corrupt the packet's data.
Did someone succeed flooding a socket stream ?
I'm using the FreeBSD stack on a cyclone II developement board with the default network settings.
thanks in advance,
sly
It is in fact a driver issue. There is a patch here (http://forum.niosforum.com/forum/lofiversion/index.php/t3277.html).
It works great now !
