I am having a problem getting my software to launch from EPCS. Here is what I have done: I am using a patch method used to boot Nios II out of EPCS for the Stratix II, with Cyclone II. I have run through the method of modifying boot_loader_epcs.srec, converting flash file to hex for EPCS, and then creating a JIC file. I have run this EPCS load successfully when I have instantiated a memory test inside of on-chip memory. I am applying the same method where I want to launch my code out of SRAM. I know the code is loaded because I open up a Nios-console session and can see my memory modified with my code. Of course, I can easily launch my software with a nios2-download -g <fn>.elf Is there a way to have the code, “go” from this address without any other intrusion, like say an IDE command or console command. I am a little confused because I can also easily compile a simple hello world onto on-chip memory and have that run without any external commands. Thanks, BaycoolLink Copied
