Software Library Project...
in the New Project wizard of the Nios II IDE, I have created a Managed Library Project. This project uses the open() function, which is declared in the fcntl.h file.
When I try to compile the project, I get errors from a chain of *.h files, ending where alt_types.h can not be found by the compiler. Apparently one of the files which get included by fcntl.h include the alt_types.h which seems to be not accessible by a Managed Library Project but normal projects compile fine with included fcntl.h.
Any ideas what the reason is or how to solve this problem?
Christian
