12748 Discussions
Some help in application selector example
Can anyone explain this function to me (I mean explaining each statment in this function and how does it work)
Note : This function is included in the app_selector_gui.c in the appication selector example which works on the Nios II embededd Cyclone III edition .
int AsPrerenderFont( unsigned char* rendered_letters[],
struct abc_font_struct font[],
int fg_color,
int bg_color )
int i;
// We're going to use the video library functions to render this, and
// since those functions expect an alt_video_display type to which to write,
// we create a small temporary one here and fill it out just enough to draw
// to it.
alt_video_display* temp_buffer;
temp_buffer = (alt_video_display*) malloc(sizeof (alt_video_display));
temp_buffer->color_depth = 32;
temp_buffer->num_frame_buffers = 1;
temp_buffer->bytes_per_pixel = ( 4 );
temp_buffer->buffer_being_written = 0;
temp_buffer->buffer_ptrs[0] = (alt_video_frame*) malloc( sizeof( alt_video_frame ));
for( i = 0; i < 94; i++ )
temp_buffer->width = font.bounds_width ;
temp_buffer->height = font.bounds_height;
temp_buffer->bytes_per_frame = (( temp_buffer->width * temp_buffer->height ) * 4 );
temp_buffer->buffer_ptrs[0]->buffer = (void*) malloc( temp_buffer->bytes_per_frame );
vid_print_char_alpha ( 0, 0, fg_color, i + 33, bg_color, font, temp_buffer );
rendered_letters[i] = temp_buffer->buffer_ptrs[0]->buffer;
free( temp_buffer->buffer_ptrs[0] );
free( temp_buffer );
return( 0 );
