12747 Discussions
Some problems with uclinux
Hi
I met following problems when I am building standard linux tasks.
->Creating a ram disk image of ext2 fs problem
My cf card is ok and creating an ext2 fs successfully.But the next step for creating a ram disk image always does not rool my hoop.
 # dd if=/dev/zero of=/dev/ram0 bs=1k count=1024]
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
/dev/ram0:No space left on device
4097+0 records in
4096+0 records out [/b]
--- Quote End ---
  # mke2fs -s0 -vm0 /dev/ram0 1024   # tune2fs -i 0 /dev/ram0   # mount /dev/ram0 /mnt  # umount /mnt  # dd if=/dev/ram0 of=ramfs1024.img count=1024
--- Quote Start ---
ramfs1024.img:Read-only file system[/b]
--- Quote End ---
# mount –n /dev/hda1 /mnt/ide0# dd if=/ramfs1024.img of=/dev/ram0
--- Quote Start ---
/ramfs1024.img:No such file or directory[/b]
--- Quote End ---
It seems that the ram image is not created.
-->Ftpd problem
I can connect and login Ok,but I can&#39;t upload. It&#39;s read-only.
How to create a rw fs?
Thank you!
I login NiosII board OK and can creat new folders by ftp. I can&#39;t see them in the LeapFTP window,But they can be found by the console. Why? Can anyone help me?
--- Quote Start ---
originally posted by singerpop@Oct 22 2005, 02:17 PM
hi
i met following problems when i am building standard linux tasks.
->creating a ram disk image of ext2 fs problem
    my cf card is ok  and creating an ext2 fs successfully.but the next step for    creating a ram disk image always does not rool my hoop.
<div class='quotetop'>quote </div>
--- quote start ---
/dev/ram0:no space left on device
4097+0 records in
4096+0 records out
--- Quote End ---
--- Quote Start ---
--- Quote End ---
--- Quote Start ---
--- Quote End ---
-->Ftpd problem
Thank you!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10524)</div>
[/b]
--- Quote End ---
Hi Singerpop!
You have not the rights to write in every directory.
I can upload via ftp files to "tmp" or "var" but e.g. not to "usr".
In creating a ram disk on nios board i have no experiences,
cause I am also a beginner.
Bye, Lothar.
