12748 Discussions
Strange effects of UART at reset
I use an UART peripheral to communicate with a computer. If I launch the program, it works correctly, but if I reset the Nios II processor I have some problems. Here I post an simpler example where I have also the problem. The first code works correctly all the time, I receive well 1234 each time I reset the cpu.
int main (void) {     printf("1234 ");     while(1); }
But if i had the usleep function, that works when I launch the program, but if I reset the cpu, it the programs sends more characters than wanted.
int main (void) {     usleep(500000);     printf("1234 ");     while(1); }
I received the following (one line by reset of cpu) :
1234
34 1234
1234 1234
234 1234 1234
4 1234 1234 1234
1234 1234 1234 1234
34 1234 1234 1234 1234
But if I have the usleep function and I remove the while(1), I receive well 1234. Anybody have an idea why I have these effects ?
Thanks in advance.
Jérôme
Do you still have the problem?
If so, could you please confirm that you get longer output string ( by 3 characters or so ) string _each_ time you reset the CPU?
At first, I thought that maybe the reset circuit had glitches and was causing the issue, but I think that would cause more random lengths, not consistently longer outputs...
Also, you could look at the assembler output, it should be quite short ( at least for the main loop ).
Also, you could try to change the compiler optimizer to a less optimized level.
Sorry for the late answer, I was not notifed. Yes the output strings was always longer by 3 characters after each reset.
I noticed similar effect on others project I made. For example, I had a project where some global variables were initialized. And sometimes, after a reset, the variables were not initialized (keeping value before the reset).
