Strange varible declare!
Hi, everyone
Have you ever met this strange problem? I have use Q2 5.0 and NIOS IDE 5.0 to develope my project. My program is running in CFI flash and my FPGA is EP1C12Q240. A simple program is this:
float a = 2100;
main()
This program is running properly. But when I change the variable "a" 's initial value to 10500, the program became this:
float a = 10500;
main()
The program DONT RUN!!!. And the program did not optimize.
So I have to initialeze the varible in the "main" program:
float a;
main()
a = 10500;
Then the program can run porperly whenever I change the initial value.
did you ever met this?
