Hello all once again ...
sorry for the continuous headaches i make http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif I'm working on my grad. project .. it's about video decoding .. i want to stream a LARGE video file over the network (from my PC) .. decode the stream under uCLinux .. then display the decoded frames(this final step is not yet done) i tried loading a small video file on the FS ,, as a test.. it works fine.. but i want to test large streams .. i need to use the network .. Hippo said that the ftp is quite easy ... but .. as far as I know .. ftp will download the whole file !! This is not what i want ..at ALL http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ohmy.gif i thought samba shares can be mounted .. and the shared files can be streamed (read) easily .. but .. i felt that the samba in uClinux is not an easy job .. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif can any1 help me ?? ,, any ideas ?? Thanks in advance http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gifLink Copied
--- Quote Start --- originally posted by tarekeldeeb@Jun 30 2006, 12:18 PM but i want to test large streams .. i need to use the network ..
hippo said that the ftp is quite easy ...
but .. as far as i know .. ftp will download the whole file !!
this is not what i want ..at all http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/ohmy.gif
i thought samba shares can be mounted .. and the shared files can be streamed (read) easily .. but .. i felt that the samba in uclinux is not an easy job .. http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/blink.gif
thanks in advance http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/biggrin.gif
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16578)
--- quote end ---
--- Quote End --- What about NFS to a linux machine....all you need is a supercheap PC, load Linux, copy your file to it, setup your NIOS board for NFS, and boot. If you already have a Linux PC you're almost there already. While I don't have much NIOS experience, I have done a lot of other Linux development on embedded platforms and have always utilized NFS mounts. This is much easier than creating a flash image everytime something changes and is meant to work as a mounted FS, so it gets around the FTP issue that you noted. SAMBA is similar, but to act as a connection to Windows FS--which throws many more variables into the mix. Keith
Hi tarekeldeeb,
> ftp will download the whole file !! ... > i felt that the samba in uClinux is not an easy job ... > ,, any ideas ?? You might want to implement a tftp clien in your application. It's not very difficult, your app can control the read requests, and there are plenty of servers you can use on unix and windoze machines. Regards, --Scott- Mark as New
--- Quote Start --- originally posted by espian@Jun 30 2006, 09:45 PM what about nfs to a linux machine....all you need is a supercheap pc, load linux, copy your file to it, setup your nios board for nfs, and boot. if you already have a linux pc you're almost there already.
while i don't have much nios experience, i have done a lot of other linux development on embedded platforms and have always utilized nfs mounts. this is much easier than creating a flash image everytime something changes and is meant to work as a mounted fs, so it gets around the ftp issue that you noted. samba is similar, but to act as a connection to windows fs--which throws many more variables into the mix.
keith
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16580)
--- quote end ---
--- Quote End --- Keith .. thanks a lot .. can you please tell me how to prepare my linux to act as a server to share on NFS ?? .. also .. will i use " mount " command on the uClinux ..or it needs a seperate client ?? .. pls help .. i feel that i miss many vital concepts http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif <div class='quotetop'>QUOTE </div> --- Quote Start --- You might want to implement a tftp clien in your application. It's not very difficult, your app can control the read requests, and there are plenty of servers you can use on unix and windoze machines. Regards, --Scott[/b] --- Quote End --- Dear Scott, .. can u please tell me a demo code example (psudo) about that .. I will appretiate any kind of help http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif Thanks guys .. you are really pushing me further .. and forward http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
--- Quote Start --- originally posted by tarekeldeeb@Jun 30 2006, 07:37 PM keith .. thanks a lot ..
can you please tell me how to prepare my linux to act as a server to share on nfs ?? .. also .. will i use " mount " command on the uclinux ..or it needs a seperate client ?? .. pls help .. i feel that i miss many vital concepts http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/sad.gif
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16588)
--- quote end ---
--- Quote End --- http://www.tldp.org/howto/nfs-howto/index.html (http://www.tldp.org/howto/nfs-howto/index.html) I started writing all of this out, but I'm sure this is much more complete. Hope this helps. Keith
Keith .. you are wonderful ..
that is exactly what i needed http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif Thanks a lot man http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif- Mark as New
use nfs, setup nfs server on a Linux PC.
http://nioswiki.jot.com/wikihome/operating...ms/nfsfilesytem (http://nioswiki.jot.com/wikihome/operatingsystems/nfsfilesytem)- Mark as New
