Structure/enum alignment
Sitanshu_N_Intel
Do we need to provide a 32 bit number for the last entity of the enum? in order to get it aligned to word boundary?
I see that if this entry is not present then I see corruption for variables before or after.
JOHI
New Contributor II
The Pragma PACK directive can be of service in your case.
However, can you provide an example of your code to clarify your issue.
A rogue pointer is more likely to be the cause of your trouble.
Johi.
Ahmed_H_Intel1
Hi Sitanshu, I think so, you have to provide a 32 bit number. Can you share a sample code to check what you are tring to do?
