12745 Discussions
System Verilog not supported by Component Editor/SOPC Builder?
I wrote a component in a ".sv" file, the module is like this:
module ir_det_ctrl # ( parameter CH = 3 )( //avl memory map slave input avl_clk, input avl_reset, input avl_read, input avl_write, input avl_address, input avl_writedata, output avl_readdata, output reg avl_irq, //conduit end input signed IrStn, input IrStnEn, output reg IrPwr );
The number of "IrStn" signal can be parameterized by "CH".
Such a coding style can be synthesised by quartus but when I create component in Component Editor, it says:
--- Quote Start ---
Error: Error: Error (10867): Verilog HDL or VHDL XML Interface error at ir_det_ctrl.sv(39): port "IrStn" has an unsupported type File: .../ir_det_ctrl.sv Line: 39
--- Quote End ---
Why SOPC Builder can not support system verilog coding while infact quartus supports it???
PS: I'm using quartus 11.0 without sp... what about new versions?
