TFTP server stack size
In case anyone else is trying to use TFTP - the default stack size for the server daemon is being calculated as 12 bytes! I looked into the CDL for this component and found that the default stack size is being calculated using symbols which are not defined (at least I couldn't find them in my installation). When I manually changed the size to 4096 in configtool, it fixed the crashes I'd been experiencing. FYI...
Yes, if you look at the .ecc, the ecos config tool doesn't seem to know the CYG default thread stack size variable. When I checked my compilation, the stack size was eventually filled in correctly even though ecos config screen was showing 12.
--- Quote Start ---
originally posted by patnystrom@Jul 9 2005, 10:08 PM
in case anyone else is trying to use tftp - the default stack size for the server daemon is being calculated as 12 bytes[/b]! I looked into the CDL for this component and found that the default stack size is being calculated using symbols which are not defined (at least I couldn't find them in my installation). When I manually changed the size to 4096 in configtool, it fixed the crashes I'd been experiencing. FYI...
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=8236)
--- Quote End ---
[/b]
--- Quote End ---
