12745 討論
Target request failed: No symbol table is loaded.
榮譽貢獻者 II
1,530 檢視
Sorry I don't mean to cross-post but I first asked this question in the following thread:
http://alteraforums.com/forum/showthread.php?t=22007
However that thread was originally created to deal with other more generic problems and my question is now more relevant to this forum.
I'm receiving the following error when I try debug on my DE2 board:
--- Quote Start ---
Unable to set temporary breakpoint in main.
Reason: Target request failed: No symbol table is loaded. Use the "file" command..
Continue?
Yes | No
--- Quote End ---
GDB console output:
--- Quote Start ---
mi_cmd_stack_list_frames: No stack.
165-target-select remote :50681
165^connected,thread-id="0",frame={addr="0x00040020",func="??",args=[]}
(gdb)
166-gdb-set new-console
&"No symbol table is loaded. Use the \"file\" command.\n"
166^error,msg="No symbol table is loaded. Use the \"file\" command."
--- Quote End ---
The debug symbols obviously aren't being loaded for some reason however I'm unsure why. I am compiling and running debug mode so I'm unsure what the problem is.
Any help would be appreciated.
0 積分
0 回應
回覆
