12745 Discussions
Terasic DE1-SoC not working with Intel SoC FPGA Edition DS-5
RHobb
I just got the DS-5 software from Intel to debug and control the HPS in the Cyclone V FPGA board I got from Terasic. The board connects, I can see the peripheral registers in the CPU, however I can't get the debug session to run. I have multiple errors (5000 plus errors). I have the path correctly set up, scatter file, preloader, .ds script, ps script, tcl script. Everything works fine on my end. But the software is just not connecting or downloading the application, or queries the socket connection continuously with faults. Anybody can help?
FawazJ_Altera
Is this DS-5 runs on Linux or Windows?
Seems it runs on Linux, and it misses some environment setup.
RHobb
I'm running a baremetal program using ARM 5 compiler. I actually just solved this problem because I had no preloader installed, and it was causing runtime errors due to the watchdog timer timing out and resetting the PC. I have loaded the included DE1-SoC computer (Intel FPGA program included with the Monitor program), which has the preloader and u-boot SPL, and at first the startup program worked which caused the 7 segment LEDS to scroll in animation, now it doesn't upon startup.
Regardless, now I'm having issues with the debugger
ERROR(?):  Value 0x574785de does not match expected value 0x5859a089/0xffffffffERROR(?):
ERROR(CMD656): The script C:\intelFPGA\18.0\embedded\ds-5\sw\debugger\configdb\Scripts\altera_target_check.py failed to complete due to an error during execution of the script
What is causing this error?
FawazJ_Altera
Its better to share the log messages to trace the issue,
FawazJ_Altera
Are you able to share with me the log mesages?
