The problem of LCD Core
Hello!
I am tring to edit a new LCD core,like this.
http://b32.photo.store.qq.com/http_imgload.cgi?/rurl4_b=b579f8b54f494fc69149a5de70a1aee91b9b9becdec16dcae957c39d05340496602d68b361471d3c000385a1ada4a41e8741cd93898a3a895c57177e8d70f2cdc77bd34267771336d1f1751edf7e1f00355521b3&a=32&b=32
I want to supply 50M clock frequency to the inclk from outside,and connect the hs,vs,red,green,blue,enable,lcdclk to the LCD.To read data from the FIFO so I connect the ready,writedata,c to the FIFO.
http://b32.photo.store.qq.com/http_imgload.cgi?/rurl4_b=b579f8b54f494fc69149a5de70a1aee9d134c640d99150ae0f0b6cff8eeded9abfb61b445eeb874d5ebf349f5ae95c614e27bf1f86c25cd595d3a3c8135c92b0a10a74da97d58a841ed6e211e6170ed4939c8544&a=31&b=32
There are a lot of errors that I cann't solve.can anyone suggest me?
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity displayer is
port(inclk:in std_logic;
hs: out std_logic;
vs: out std_logic;
datain:in std_logic_vector(23 downto 0);
red: out std_logic_vector(7 downto 0);
green: out std_logic_vector(7 downto 0);
blue: out std_logic_vector(7 downto 0);
ready: out std_logic;
c: out std_logic);
end displayer;
architecture behave of displayer is
signal fcounter:std_logic_vector(2 downto 0);
signal hcounter:std_logic_vector(8 downto 0);
signal vcounter:std_logic_vector(8 downto 0);
signal hsync,vsync:std_logic;
signal fclk:std_logic;
begin
process(inclk)
begin
if(inclk'event and inclk='1')then
fcounter<=fcounter+1;
end if;
end process;
fclk<=fcounter(2);
process(fclk)
begin
if(fclk'event and fclk='1')then
if(hcounter=408)then
hcounter<=(others=>'0');
else
hcounter<=hcounter+1;
end if;
end if;
end process;
process(fclk)
begin
if(hcounter=388)then
if(vcounter=270)then
vcounter<=(others=>'0');
else
vcounter<=vcounter+1;
end if;
end if;
end if;
end process;
process(hcounter)
begin
if(hcounter<30)then
hsync<='0';
else
hsync<='1';
end if;
end process;
process(vcounter)
begin
if(vcounter<3)then
vsync<='0';
else
vsync<='1';
end if;
end process;
process(hcounter,vcounter)
begin
if(hcounter>68 and hcounter<388 and vcounter>18 and vcounter<258)then
ready<='1';
else
ready<='0';
end if;
end process;
blue<=datain(7 downto 0);
red<=datain(15 downto 8);
green<=datain(23 downto 16);
hs<=hsync;
vs<=vsync;
c<=fclk;
end behave;
thanks in advance!
&#20320;&#21487;&#20197;&#21152;&#19968;&#19979;&#25105;&#30340;qq&#65292;&#25105;&#21644;&#20320;&#20180;&#32454;&#25506;&#35752;&#65292;12&#65306;00-0&#65306;00&#26377;&#26102;&#38388;&#65292;&#20854;&#20182;&#26102;&#38388;&#22312;&#30561;&#35273;&#12290;
&#40635;&#28902;&#20320;&#25226;QQ&#21495;&#21457;&#21040;&#25105;&#30340;&#37038;&#31665;
li_polaris_1988@yahoo.cn
thank you very much!
