12748 Discussions
The problem of multi_cycle custom instruction
Hi!
I want to learn the multi_cycle custom instruction,so I write an code randomly.
but the instruction didn't work in the NIOS IDE.I cann't find the error of the code,please help me.
library ieee;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
entity move is
port(dataa:in std_logic_vector(31 downto 0);
datab:in std_logic_vector(31 downto 0);
result:out std_logic_vector(31 downto 0);
clk:in std_logic;
clk_en:in std_logic;
start:in std_logic;
reset:in std_logic;
done:out std_logic);
end move;
architecture behave of move is
signal t:std_logic_vector(3 downto 0);
signal a:std_logic_vector(31 downto 0);
signal b:std_logic_vector(31 downto 0);
begin
process(clk,clk_en,reset)
begin
if(clk_en='1')then
if(start='1')then
a<=dataa;
b<=datab;
t<="0000";
elsif(t<"1111")then
if(clk'event and clk='1')then
a<=a+1;
b<=b+1;
t<=t+1;
end if;
end if;
end if;
end process;
process(t,a,b)
begin
if(t="1111")then
done<='1';
result<=a+b;
else
done<='0';
end if;
end process;
end behave;
thanks in advance!
This is only template for guidance(haven't checked syntax)
library ieee; use ieee.std_logic_1164.all; entity move is port( dataa: in std_logic_vector(31 downto 0); datab: in std_logic_vector(31 downto 0); result: out std_logic_vector(31 downto 0); clk: in std_logic; clk_en :in std_logic; start: in std_logic; reset: in std_logic; done: out std_logic ); end move; architecture behave of move is signal t: std_logic_vector(3 downto 0); signal a: std_logic_vector(31 downto 0); signal b: std_logic_vector(31 downto 0); begin process(clk,reset) begin if(reset = '1')then a <= (others => '0'); b <= (others => '0'); t <= (others => '0'); done <= '0'; result <= (others => '0'); elsif(clk'event and clk='1')then if(clk_en = '1')then if(start = '1')then a <= dataa; b <= datab; t <= "0000"; done <= '0'; result <= (others => '0'); end if; if(t < "1111")then a <= a+1; b <= b+1; t <= t+1; done <= '0'; else done <= '1'; result <= a+b; end if; end if; end if; end process; end behave;
I'm sorrow,it doesn't work.
