12620 Discussions
Triple-Speed Ethernet with ksz8893
I want to use the mii of ksz8893 connect to Triple-Speed Ethernet ,but it cannot work.
my socket can listenning, but i cannot ping from pc.please tell me what should i do?
--- Quote Start ---
So you would only need to check the connection status of the other 2 PHYs, and return when one is connected.
If you don't care whether a line is connected or not (as is possible for testing), just return any correct value for the link status
--- Quote End ---
Thanks my friend,
you mean,I don't need to check the 3th mac(link to my mii)?
I just check phy1 or phy2 link good?
Hi my friends,
This is my new report,
--- Quote Start ---
Please enter your 9-digit serial number. This is printed on a
label under your Nios dev. board. The first 3 digits of the
label are ASJ and the serial number follows this.
-->Created "Inet main" task (Prio: 2)
Created "clock tick" task (Prio: 3)
123456789
123456789
Your Ethernet MAC address is ff:ff:ff:ff:38:55
Static IP Address is 192.168.1.30
prepped 1 interface, initializing...
[tse_mac_init]
INFO : TSE MAC 0 found at address 0x0a005000
INFO : PHY KSZ8893 found at PHY address 0x01 of MAC Group[0]
INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0]
INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link...
INFO : PHY[0.0] - Auto-Negotiation PASSED
INFO : PHY[0.0] - Checking link...
INFO : PHY[0.0] - Link established
INFO : PHY[0.0] - Speed = 100, Duplex = Full
OK, x=0, CMD_CONFIG=0x01000000
MAC post-initialization: CMD_CONFIG=0x05000203
[tse_sgdma_read_init] RX descriptor chain desc (1 depth) created
mctest init called
IP address of et1 : 192.168.1.30
Simple Socket Server starting up
[sss_task] Simple Socket Server listening on port 30
Created "simple socket server" task (Prio: 4)
--- Quote End ---
I still cannot ping through from pc to my nios.
I had check my ksz8893's mii by omap-L138, and it can work good.
What should I do?
Thank you very much !!
Hi all my friends,
Thanks for your help, my ksz8893 has been working well.
Thanks again!
--- Quote Start ---
Hi all my friends,
Thanks again!
--- Quote End ---
If available, please show the code for other persons, that may have such problems in the future.
--- Quote Start ---
--- Quote End ---
I will post my code and project in the next few days, I am ordering them.
I have meet the same problem,could you tell me how to fix it?
