12618 Discussions
Trouble of NIOS2's timer interrupt
HI everyone
i have purchased the NIOS2 evaluate board--EP1C12 from the Altera. and i program a timer interrupt routine to create a square wave based on the evaluate board's standard design. my routines is below:# include "system.h"# include "sys/alt_irq.h"# include "altera_avalon_pio_regs.h"# include "altera_avalon_timer_regs.h"# include "alt_types.h"
alt_u8 x = 0x55;
static void timer_interrupts(void* context, alt_u32 id)
IOWR_ALTERA_AVALON_TIMER_STATUS(SYS_CLOCK_TIMER_BASE, 0);
x = x ^ 0xFF;
IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, x);
int main()
alt_irq_register(SYS_CLOCK_TIMER_IRQ, 0, timer_interrupts);
IOWR_ALTERA_AVALON_TIMER_PERIODL(SYS_CLOCK_TIMER_BASE, 0x1F40);// timer interrupt period is 100us
IOWR_ALTERA_AVALON_TIMER_PERIODH(SYS_CLOCK_TIMER_BASE, 0x00);
IOWR_ALTERA_AVALON_TIMER_CONTROL(SYS_CLOCK_TIMER_BASE, 7);
while(1)
i download the routine into the evaluate board and run it, then the square wave's period is 200us as designed. when i add some float calculation in the ISR, the period changed and bacame more than designed. the ISR is below:
float i;
x = x ^ 0xFF;
for(i=0;i<100;i++);
The period is 2.784ms!!!!!!
If "float" became "alt_u8", the period is 200us as designed.
alt_u8 i;
x = x ^ 0xFF;
for(i=0;i<100;i++);
I wonder if there can not be float calculation in the timer interrupt or the float calculation is very slow in NIOS2????
--- Quote Start ---
originally posted by oceanx@Dec 8 2005, 02:34 PM
i wonder if there can not be float calculation in the timer interrupt or the float calculation is very slow in nios2????
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11424)
--- quote end ---
--- Quote End ---
It could be... Nios II does not have a FPU... The 1 ms period could be because the duration of the ISR is greater than the ISR period...
bye
Paolo
Thanks, Paolo
It seems like that i must let the "main" function to do the float calculation, right? I worry about if it can be competent for the calculation or not.
We must not add float calculation in the ISR?
Best Regards
--- Quote Start ---
originally posted by oceanx@Dec 9 2005, 08:56 AM
thanks, paolo
it seems like that i must let the "main" function to do the float calculation, right? i worry about if it can be competent for the calculation or not.
we must not add float calculation in the isr?
best regards
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11451)
--- quote end ---
--- Quote End ---
Without floating point hardware, a set of software emulation libraries is used when you use float numbers in a program. These tend to be very, very slow, but they do work.
If you want to speed up floating point arithmetic, there are some custom instruction examples posted in the "projects" are of this forum which may be useful.
In addition, when writing interrupt handling code it is recomended in the Altera software developer&#39;s manual that interrupt service routines be as short and efficient as possible. It is far better, for example, for the interrupt routine to set a pointer or signal so that some other (non-interrupt task) can then go perform the slow calculation.
--- Quote Start ---
originally posted by jesse@Dec 10 2005, 03:53 AM
without floating point hardware, a set of software emulation libraries is used when you use float numbers in a program. these tend to be very, very slow, but they do work.
if you want to speed up floating point arithmetic, there are some custom instruction examples posted in the "projects" are of this forum which may be useful.
in addition, when writing interrupt handling code it is recomended in the altera software developer&#39;s manual that interrupt service routines be as short and efficient as possible. it is far better, for example, for the interrupt routine to set a pointer or signal so that some other (non-interrupt task) can then go perform the slow calculation.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11459)
--- quote end ---
--- Quote End ---
Thanks, Jesse
i will try it again. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
Best Regards
