I had some trouble (see my previous post) (http://forum.niosforum.com/forum/index.php?showtopic=6810) to run the NIOS II processor without chaniging anything ! Because I don't find any way to solve my problem I decided to close all apps, restart the computer and to make a very new Quartus II project (in a new directory..) In SOPC I add only three component : - The NIOS II processor - An onchip_mem - A Jtag_uart In the Block diagram file I add only two input pins, thelock and the reset (which is negative logic, of course..) I have a good compilation in Quartus II and when I program the FPGA, I get the OpenCore Status window which is connect without any problem ! Then I launched a new NIOS II project (with a new workspace....) I made a hello_world_small project.. The compilation was successful but I get this message in the output console !Using cable "USB-Blaster ", device 1, instance 0x00
Pausing target processor: not responding.
Resetting and trying again: FAILED
Leaving target processor paused
I don't understand why I have this problem without changing anything !! Please help me ! Thank you..
