12745 ディスカッション
UART 16550 vs standard UART
名誉コントリビューター II
7,733件の閲覧回数
Hi all,
is there a simple way of replacing the standard UART, which is in all examples, with the UART16550?
I mean, that simply all stdin/stdout/stderr goes to the UART16550?
I can only have one UART in the system, and would remove then the standard UART ...
Thanks!
0 件の賞賛
18 返答(返信)
名誉コントリビューター II
5,230件の閲覧回数
Hi all,
just tried to get the 16550 UART to work at all, but no output so far. I tried to implement, what is in the the "ug_embedded_ip" manual, but so far no luck.
Is there anything obvious missing, or wrong:
# include <stdio.h>
# include <stdlib.h>
# include <sys/ioctl.h>
# include <sys/termios.h>
# include <fcntl.h>
# include <string.h>
# include <unistd.h>
# include <sys/time.h>
# include <time.h>
# include "system.h"
# include "altera_16550_uart.h"
# include "altera_16550_uart_regs.h"
# define BUFSIZE 512
char TXMessage[BUFSIZE] = "Hello World, UART16550 sending\n";
int UARTDefaultConfig(UartConfig *Config)
Config->stop_bit = STOPB_1;
Config->parity_bit = NO_PARITY;
Config->data_bit = CS_8;
Config->baudrate = BR115200;
Config->fifo_mode = 0;
Config->hwfc = 0;
Config->rx_fifo_level= RXFULL;
Config->tx_fifo_level= TXEMPTY;
return 0;
int UARTBaudRateTest()
UartConfig *UART0_Config = malloc(1*sizeof(UartConfig));
altera_16550_uart_state* uart_0;
uart_0 = altera_16550_uart_open ("/dev/a_16550_uart_0");
UARTDefaultConfig(UART0_Config);
altera_16550_uart_write(uart_0, &TXMessage, strlen(TXMessage), 0);
usleep(1000);
free(UART0_Config);
return (0);
int main()
int result=0;
result = UARTBaudRateTest();
Thanks!
名誉コントリビューター II
5,230件の閲覧回数
What you mean by replacing the standard UART?
How about changing the BSP settings (stdin, stdout, stderr) to 16550 UART?
Are you trying to printf output through 16550 UART IP instead of RS232 UART IP?
名誉コントリビューター II
5,230件の閲覧回数
I had a look at using the 16550 UART. In the end I found it much easier to use this one:-
http://www.alterawiki.com/wiki/fifoed_avalon_uart
It is exactly the same to use as the standard Altera UART but offers buffering, higher speed, RS485 driver enable + lots more. Well worth a look.
名誉コントリビューター II
5,230件の閲覧回数
--- Quote Start ---
--- Quote End ---
yes!
--- Quote Start ---
--- Quote End ---
Exactly. I saw in another post, that you should be able to simply replace the "uart0" in the BSP_HAL editor,
but in the setttings HAL/Common stdin/stdout/stderr, the only entry is "none" and the a_16550_uart_0 can't be selected.
Do I have to rename the instance of "a_16550_uart_0" to "uart_0" in qsys?
Thanks!
名誉コントリビューター II
5,230件の閲覧回数
I suspect you observed "none" in the settings due to the Qsys generated files are not refreshed/synced with your SBT.
Try reload the .sopcinfo file and create new BSP. You do not have to rename as the settings should reflect the name in Qsys.
名誉コントリビューター II
5,230件の閲覧回数
--- Quote Start ---
--- Quote End ---
I tried that too, and the 16550_uart doesn't show :(
名誉コントリビューター II
5,230件の閲覧回数
Did you export those UART signals in Qsys?
名誉コントリビューター II
5,230件の閲覧回数
--- Quote Start ---
--- Quote End ---
Yes, they also show up in the .bdf file and are connected there ...
名誉コントリビューター II
5,230件の閲覧回数
Have you tried if JTAG UART works?
名誉コントリビューター II
5,230件の閲覧回数
--- Quote Start ---
--- Quote End ---
No. I had the "standard" UART in before, got my application working, but needed one with a FIFO. So tried to get the 16550-UART to work, without success.
What I'm really trying is to get the RSU working (application note 741), so my NIOS system is pretty simple, basically using the AN-741 template, and replacing
the UART in it with the 16550-UART. Any chance anybody else can try it?
名誉コントリビューター II
5,230件の閲覧回数
--- Quote Start ---
--- Quote End ---
And, all of this is done on MAX10, and the Altera DK-DEV-10M50 board...
名誉コントリビューター II
5,230件の閲覧回数
Sorry that I am confused. For your working design, you must have seen the RS232 UART in BSP setting. But you are saying that you get "none".
So which is correct?
名誉コントリビューター II
5,230件の閲覧回数
--- Quote Start ---
--- Quote End ---
No problem ;-)
what I did:
a.) used the RSU AN741 template, generated a NIOS system, with an UART, which was working, I could "see" the UART in the BSP-Editor.
However, the performance for our application wasn't sufficient, so we tried to install the 16550-UART, which has big FIFOs, which we thought would
improve the performance on the serial line.
b.) We added the a_16550_uart to our QSYS design, but it doesn't show up in the BSP editor. Only the "standard" uart_0 is there.
c.) we removed the standard uart_0 from the QSYS, and now there aren't any UART anymore to select in the BSP editor.
So, what are we doing wrong, that the a_16550_uart doesn't show up in the BSP editor, as an UART for stdin/stdout/stderr?
thanks!
名誉コントリビューター II
5,230件の閲覧回数
I have tried to replicate your issue and observed the same behavior.
Most likely this is due to the HAL driver for 16550 UART is not ready for such BSP configuration :(
名誉コントリビューター II
5,230件の閲覧回数
--- Quote Start ---
--- Quote End ---
Thanks a lot for trying!
I was going nuts, as I thought I'm doing something wrong, and in other posts it sounded to easy ;-)
Altera: any chance to fix this?
Thanks again!
名誉コントリビューター II
5,230件の閲覧回数
This issue has been logged. Let's look forward to the fix in near future :)
名誉コントリビューター II
5,230件の閲覧回数
--- Quote Start ---
--- Quote End ---
Excellent!
Will there be a patch,
or do we have to wait for 16.3 or 17.0?
Thanks!
名誉コントリビューター II
5,230件の閲覧回数
The delivery milestone is undecided at the moment.
返信
