12748 Discussions
UART ECHO on incomming with __getline()
Is there a way to have the UART echo all input, while still using the stdio.h functions?
I developed my application using the NIOS EDS, where you can see everything you type and no command is sent until one hits <enter>.
The nios2-terminal and hyper-terminal in windows do not have this behavior.
I need to provide an echo function while preferably being able to use the fprintf() and __getline() functions. I am supporting both RS-232 and the JTAG UART.
Thank you,
Jeff
