UDP Socket in Niche Stack
Hi
Can Any one Help me plz in Niche stack.I want to know that how can we create a udp socket in Nichestack and send data or listen this socket to receive data.
Its Urgent..................... PLZ
Hasil86
Unless you're using Superloop Nichestack....the same way you would for any other TCP/IP stack that supports the sockets API standard.
Also, this question has definitely been asked before and I believe there's even a few examples...either here or on alterawiki.com.
Cheers,
slacker
These Example are so tough for Beginners .........
You don't have to use asynchronous sockets (which, I admit, are harder to understand). I would start with something like the following:
http://www.abc.se/~m6695/udp.html
There will be small differences to get this functional with Interniche sockets, slightly more with the strangeness that is winsock, but it should work.
Cheers,
slacker
OOOH Yes ..................
I have done it...............
Yah000000000000000000000
Thanks slacker
hi I am working on UDP Socket between DE2 board and PC. Could you show me how you were done UDP on DE2 board? (I am sending back and forth one character, like chatting)
on De2 you would have to install uclinux or micro tcp/ip with micro c os2 to create the udp socket.As the de2 board has dm9000 ethernet controller which is not supported by interniche stack.
i have done it on de2-115 which have triple speed ethernet which is supported by interniche stack.
Hasil86
--- Quote Start ---
Hasil86
--- Quote End ---
Hi, as you say about triple speed Ethernet, you meant that you selected the Triple Speed Ethernet IP Core under Series Communication in SOPC. Is it right? Does it work as the same chip with DM9000A? Or that is the other chip on specific board? I am using DE2-70 Board, but there is nothing about Triple Speed Ethernet on the Manual Document.
Thank you for your help!
Triple Speed Ethernet IP doesnt work with dm9000A .It only Works with de2-115 .This is specific to de2-115 .
The only possible solution for networking using sockets in De2-70
1.UClinux
2.Micro C OS2 + Micro C Tcp/ip
But i didnt done both of the solution.
so you have to workout
Hi Hasil,
I've got a DE2-115 and trying to get an ethernet connection to the PC, which i'm strucggling with. DO you know a good place to learn from or do you have working code that i can disect so I may teach myself?
I have done the Ethernet Connection between DE2-70 and PC, I am using DM9000A with UDP socket wrap by manually define Ethernet, IP, and UDP Checksum. On PC side I am running JAVA Programming, you have to do the same on PC side by manually program by RAW socket.
Here the link with very useful projects, which done Ethernet Connection on DE2 board.
http://www.cs.columbia.edu/~sedwards/classes/2011/4840/index.html (http://www.cs.columbia.edu/~sedwards/classes/2011/4840/index.html)
--- Quote Start ---
Hi Hasil,
--- Quote End ---
You have to read file: DE2_115_Web_Server demonstration project to start learning the communication.But first you have a sound knowledge of BSD Sockets API.
Feel free to contact for queries....
Hasil86
Can someone please help me in writing a program for server and client on nios II EDS using Nichestack TCP/IP. I want to communicate between two pc's using a altera startix board on one computer by an ethernet cable.Nios II eds has "simple socket server" example provided by altera. modifying that i want to create my own program which will enable me to transfer data from one pc which will act as server and another pc which will act as client.
I'm still in the middle of learning, but these are helping me currently:
http://en.wikipedia.org/wiki/bsd_socket Explains sockets and this is what the niche stack is built on.
The link posted by someone in the second post
and the book "TCP/IP Sockets in C" by Donahoo and Calvert.
Sorry i can't help more i'm still trying to customise and learn atm.
First off, you don't want to use "simple" socket server to start learning about sockets. It (along with most/all of the other provided examples) make use of asynchronous sockets. While not too difficult to understand, they are more complex (and efficient) than what is necessary to setup a simple communications/data transfer medium.
I like W. Richard Stevens' classic "unix network programming (http://www.kohala.com/start/unp.html)" (the first edition). The source code at the link should be enough to get you going...it worked for me... The tftp server/client was particular useful.
Cheers,
slacker
Hi Sir,
I did manage to send UDP packet with DM9000A PHY/MAC using Altera DE2 board.
Since i am using window, i am using the winsock program instead of bsd to receive the udp packet as show in the link below:
http://www.codeproject.com/kb/ip/udptime.aspx
But the code hang at the code line below:
recvfrom(sd, (char *)&current_time,
(int)sizeof(current_time), 0,
(struct sockaddr *)&server,
&server_length) < 0)
Anybody have experience using winsock here? Please give me some help.
--- Quote Start ---
Thanks slacker
--- Quote End ---
hi,hasil86
It's hard for me to use Niche stack.Can you help me?
thank you very much!!
