12612 Discussions
URGENT HELP re: toggle switches on DE2
Hey folks,
We are working with DE2 board and are having problems with toggle switches. In our program, we used IORD_ALTERA_AVALON_... to read the input from the switch and whether it is up or down (ie 1 or 0), we are always reading 1. Not sure what the problem is. Would appreciate any positive information ASAP.
I've created a design with the following components:
Nios II/s
Onchip memory
- 32 KB
PIO 0
- 18 output only
- Base address 8800
- Connected to the Red LEDs
PIO 1
- 18 input only
- Base address 8810
- Connected to the Switches
Ran the following code which continuously reads the switches and writes their values to the LEDs:
#include <io.h> void main(void) {    int sw_data;    while (1)    {        sw_data = IORD_32DIRECT(0x8810, 0);        IOWR_32DIRECT(0x8800, 0, sw_data);    }    return; }
Seems to work.
A Common Pitfall:
- Not assigning pins to signals in the assignment editor.
Good luck,
Blair
--- Quote Start ---
originally posted by theguru@Mar 20 2007, 02:49 PM
i&#39;ve created a design with the following components:
nios ii/s
onchip memory
- 32 kb
pio 0
- 18 output only
- base address 8800
- connected to the red leds
pio 1
- 18 input only
- base address 8810
- connected to the switches
ran the following code which continuously reads the switches and writes their values to the leds:
#include <io.h> void main(void) {    int sw_data;    while (1)    {        sw_data = iord_32direct(0x8810, 0);        iowr_32direct(0x8800, 0, sw_data);    }    return; }
seems to work.
a common pitfall:
- not assigning pins to signals in the assignment editor.
good luck,
blair
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22367)</div>
--- Quote End ---
Thansk Blair. Will test that out and see what happens...
