Verify failed problem!
Welcome To Altera SOPC Builder
Version 6.0, Built Mon Apr 24 15:26:45 PDT 2006
Welcome to the Nios II Embedded Design Suite
Version 6.0, Built Fri Apr 21 04:12:54 PDT 2006
hi,everybody
I used DE2_NET project and running on DE2 Board , anything is ok.
but when i building a new nios.ptf and running on DE2 Board.
It's has following problem.
Anyone known how to slave this problem.
Need your help!
NiosQ
Example designs can be found in
/cygdrive/c/altera/kits/nios2_60/examples
(You may add a startup script: c:/altera/kits/nios2_60/user.bashrc)
[SOPC Builder]$ cd c:
/cygdrive/c
[SOPC Builder]$ nios2-download -g zImage
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Pausing target processor: OK
Initializing CPU cache (if present)
OK
Downloaded 1251KB in 15.9s (78.6KB/s)
Verifying 00500000 ( 0%)
Verify failed between address 0x500000 and 0x502A2D
Leaving target processor paused
/cygdrive/c
[SOPC Builder]$
The later DE2 support disc v1.3-v1.5 have problem in sof, and will cause jtag download error.
Please use v1.1 attached in the wiki,
http://nioswiki.jot.com/wikihome/operating...e2_net_v1.1.zip (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/tryoutuclinux/de2_net_v1.1.zip
On the DE2 support disc v1.1 nios_0.ptf, sdram base at 0x00000000. The later v1.3-v1.5 system_0.ptf have sdram base at 0x00800000 and strange sof, and will cause jtag download verify error. If you recompile v1.3-v1.5, you will need to do hwselect again.
