12745 Discussions
USB connection to PC MicrotronixStratixBoard
the other post doesnot work, so here is my question again:
Hello everybody,
I got a problem with the USB connection from the Microtronix-Stratix Board to the PC.
The PC recognizes the board (USBChip: Cypress SL811HST configured as HOST) only under weird circumstances.
I have to plugin my private USB-Stick (so there must be an existing USB Connection to the PC, i only got an USB Stick), have to pull out the Supply of the Micro.Board. (....and close one eye).
When I connect now the Board to the PC, it works, ("unknow Device"). Now I can connct
When I configure the SL811 as an Slave it doesnot work. when I supply the Board with power before I connect the USB-cable, it doesnot work.
Has anyone an idea what the problem is?
I don't have a windowsdriver for the USBChip right now, maybe thats a point.
Another Question:
I am trying to make a driver for the SL811HST with WinDriverUSB. For that I need to know the Vendor and Product ID. Can I choose them or are they fixed from device to device?
Has anyone experiences with this Board and an USB-Interface to the Computer?
Thank you,
Roman
