I'm trying to compile version 2.6 of the Microtronix uClinux kernel to include support for USB. I'm working with the Microtronix Stratix development board which has a Cypress SL811 device on it. I can see the driver code for the SL811 down in the linux/drivers/usb source tree; however I don't see the options to enable these drivers in the kernel configuration screens. The only option available under USB support is "USB Gadget Support". How do I enable support for the SL811 drivers in the kernel configuration? Thanks. TerryLink Copied
I found the problem.
Line 11 of the <linux-src>/drivers/usb/Kconfig file should be: depends on PCI || SA1111 || ARCH_OMAP1510 || ARCH_OMAP1610 || NIOS || NIOS2 instead of depends on PCI || SA1111 || ARCH_OMAP1510 || ARCH_OMAP1610 || NIOS Also, line 75 of <linux-src>/drivers/usb/host/Kconfig should be: depends on (ARM && USB) || ((NIOS || NIOS2) && USB) instead of depends on (ARM && USB) || (NIOS && USB) -- Terry
