Unable to create socket
When i booting uClinux the folling message i get:
uClinux/Nios II Altera Nios II support (C) 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: root=/dev/mtdblock0 ro PID hash table entries: 128 (order: 7, 2048 bytes) Dentry cache hash table entries: 4096 (order: 2, 16384 bytes) Inode-cache hash table entries: 2048 (order: 1, 8192 bytes) Memory available: 14944k/16384k RAM, 0k/0k ROM (992k kernel code, 254k data) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) NET: Registered protocol family 16 NIOS serial driver version 0.0 ttyS0 (irq = 4) is a builtin NIOS UART Serial: JTAG UART driver $Revision: 1.3 $ ttyJ0 at MMIO 0x821208b0 (irq = 1) is a jtag_uart RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize smc_probe: 70000 Khz Nios SMSC LAN91C111 Driver (v2.1), (Linux Kernel 2.6) eth0: SMC91C11xFD(rev:1) at 0x82110300 IRQ:6 MEMSIZE:8192b NOWAIT:0 ADDR: 00:07: ed:0d:b1:df smc_probe: 70000 Khz Nios Using anticipatory io scheduler Altera NDK flash (AMD): Found 1 x16 devices at 0x0 in 8-bit bank Amd/Fujitsu Extended Query Table at 0x0040 Altera NDK flash (AMD): CFI does not contain boot bank location. Assuming top. number of CFI chips: 1 cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness. cmdlinepart partition parsing not available RedBoot partition parsing not available Using Altera NDK partition definition Creating 4 MTD partitions on "Altera NDK flash (AMD)": 0x00200000-0x00600000 : "romfs/jffs2" 0x00000000-0x00200000 : "loader/kernel" 0x00600000-0x00700000 : "User configuration" 0x00700000-0x00800000 : "safe configuration" VFS: Mounted root (romfs filesystem) readonly. Freeing unused kernel memory: 40k freed (0x1120000 - 0x1129000) expand: from=/ramfs.img to=/dev/ram0 expand: from=/ramfs.img to=/dev/ram1 SIOCSIFADDR=-1: 9 SIOCGIFFLAGS = -1: Bad file descriptor (9) SIOCADDRT=-1: 9 Unable to create socket close on exec: : Bad file descriptor setsockopt: : Bad file descriptor Unable to bind server socket: : Bad file descriptor Unable to listen to socket Unable to create socket close on exec: : Bad file descriptor setsockopt: : Bad file descriptor Unable to bind server socket: : Bad file descriptor Unable to listen to socket Unable to create socket close on exec: : Bad file descriptor setsockopt: : Bad file descriptor Unable to bind server socket: : Bad file descriptor Unable to listen to socket
The i can login and so on.
I am using a altera nios dev board stratix2s60es
And i am using the sof file at the location C:\altera\kits\nios2\examples\vhdl\niosII_stratixII_2s60_ES\standard
Can someone help ?
Already fixed. Compiled a new *.sof file and new kernell.
