Unable to open flash-device
Hi lads , does any body know haw to solve this one :
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
10 juin 2005 16:59:16 - (INFO) nios2-flash-programmer: Launching
Quartus  Programmer to download:
  C:/altera/kits/nios2/components/ZC005/system/ZC005.sof
10 juin 2005 16:59:23 - (GRAVE) nios2-flash-programmer: Error opening
target hardware
10 juin 2005 16:59:23 - (GRAVE) nios2-flash-programmer:    Unable to
open flash-device after successfully communicating
with target.
It is likely that you are using a flash-programming FPGA design which
was not created for your target board.[/b]
--- Quote End ---
- I can program my EPCS all right with the JTAG, so my JTAG_UART is fine.
- I am using a 1 MBytes 29LV081B-70 Flash with Thold = Tsetup = 40 ns and Twait = 160 ns
- I have try to increased my PLL clock from 50 MHz to 70 MHz, without success.
does anybody have any ideas ???.
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif .
gregoryw,
This message means that programming is failing in the first step, downloading the programming .sof to the board. This programming operation is downloading to the FPGA -- if you have a different JTAG header on your board that you were using for the EPCS chip independently, you might double check to see that the cable is correct.
I can program the EPCS with the JTAG using the flash programmer , and I can also use it to debug on the IDE console when I am using OnChipMemory, so I think the JTAG is OK. Any others ideas ?.
greg.
An update : when I run the memtest from the SRAM and I try to test my flash, I get the following message :
--- Quote Start ---
      Memory Test Main Menu
  a:  Test RAM
  b:  Test Flash
  q:  Exit
Select Choice (a-http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif : [Followed by <enter>]b
Enter the name of the CFI flash device to be opened,
or just press <enter> to open "/dev/ext_flash")
-ERROR: Could not open /dev/ext_flash[/b]
--- Quote End ---
it seems that my AMD flash can not be reconized. So I m wondering if there is a list somewhere in the ALTERA sources that tells how to reconize if a flash is an AMD an INTEL or something else ???.
heeeeeelp http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
