Unable to synchronize with target
명예로운 기여자 II
1,125 조회수
Hello everyone,
My software is Quartus 4.2 and NiosII 1.1
I used the procedure described in the doc to build a program, debug it and download it to the demo board. With no problems (apparently)
Then i create my target board (with a cylcone EPIC20F400C7, 1 EPCS4, 2 SRAM IDT71V416S, 1 Flash AM29LV065D). With SOPC i generate the Nios component, then i compiled it with quartus, then i downloaded the code with the NIOS IDE (Using debug function). EVERYTHING seems to work OK (I mean, the LCD works, the serial ports works, all the signals I expect to be present, are present.
The problem is when i try to use the Flash programmer with my target. Infact I got a message error
"Unable to synchronize with target.
"make: *** [epcs_controller_boot_rom_programflash] Error 6
I checked for some problems on my target, but to me it seems to be all OK.
I looked in this forum if someother had the same problem, and i read to check the memory (with memtest). I did it but the problem is still present.
Thanks in advance to anyone that can give me some suggestion.
0 포인트
1 응답
명예로운 기여자 II
414 조회수
did you define the PLL?
0 포인트
응답
