I am now running on a NEEK using the Igor MAC to connect to ethernet with a National PHY.
My MAC is configured as follows in HW: Descriptors:128 Transmit buffer: 2048B Receive buffer: 4096B I can ping TO outside, and I can ping FROM outside but... When I allow ping to use its default packet size, I *always* get errors like this: oeth: tx14,00a34900 This seems to be sensitive to the packet size, since when I "ping <ip> -s 5", resulting in a 5 byte payload, the problem gets better(still happens sometimes). When It does happen, the interface is pretty hosed up, and doesn't really respond anymore. When I looked into open_eth.h, I found that errors are reported in the low 9 bits of the bdp structure (which I don't really understand B.T.W....first time in this code). The above code corresponds to OETH_TX_BD_UNDERRUN Can anyone tell me what this means, and why I may be seeing it?Link Copied
