I know about the disadvantages described here (http://www.nioswiki.com/operatingsystems/uclinux) <div class='quotetop'>QUOTE </div> --- Quote Start --- # It is synced up to the latest Linux kernel release, which means improvements, bugfixes and more drivers supported. If you will develope drivers, it is important to keep up.[/b] --- Quote End --- but is there a solution to get the new kernel into the Microtronix release?Link Copied
I don't see how this would make any sense, as there is no support whatsover for the Microtronix "release" any more.
What are you trying to accomplish ? -Michael- Mark as New
<div class='quotetop'>QUOTE (mschnell @ Jul 30 2009, 04:21 AM) <{post_snapback}> (index.php?act=findpost&pid=23336)</div>
--- Quote Start --- I don't see how this would make any sense, as there is no support whatsover for the Microtronix "release" any more. What are you trying to accomplish ? -Michael[/b] --- Quote End --- I'm trying to accomplish a simple way to work with uClinux in Windows. and the Microtronix Release runs there very good. I tried several ways, Colinux / Virtual Box is a Virtual Machine (i tried ... both worked but this solution isnt very comfortable :) ) and Cygwin failed in checkout and compiling. After browsing through the eclipse plugins i saw the Linux Kernel in a folder com.microtronix.nios2linux.kernel_1.4.0\linux-2.6.x so i thought an update there shouldn't be a big deal.- Mark as New
<div class='quotetop'>QUOTE (Dschingis @ Jul 30 2009, 10:57 AM) <{post_snapback}> (index.php?act=findpost&pid=23338)</div>
--- Quote Start --- I'm trying to accomplish a simple way to work with uClinux in Windows. and the Microtronix Release runs there very good.[/b] --- Quote End --- While I don't think this is worth the effort (as it's a real plus to have a PC Linux at hand while doing embedded Linux software: you can try out nearly everything on the PC _much_ faster than testing it on the device), I suppose the only viable way is to try to get the _current_ tool chain running in the environment you desire. This of course is possible using Cygwin. <div class='quotetop'>QUOTE (Dschingis @ Jul 30 2009, 10:57 AM) <{post_snapback}> (index.php?act=findpost&pid=23338)</div> --- Quote Start --- Cygwin failed in checkout and compiling.[/b] --- Quote End --- Of course you need to "port" the toolchain to Cygwin. I have no idea how to do that but you need to compile the gcc3 with the windows host gcc and link it against the Cygwin libraries. <div class='quotetop'>QUOTE (Dschingis @ Jul 30 2009, 10:57 AM) <{post_snapback}> (index.php?act=findpost&pid=23338)</div> --- Quote Start --- ...i thought an update there shouldn't be a big deal.[/b] --- Quote End --- Good luck :P -Michael
