12608 Discussions
Updating e2fsprogs for ext4 support
I'm wanting to experiment with the performance capabilities of EXT4 on a Compact Flash on my Cyclone II Dev Board .
In the filesystems I have enabled EXT4 and I've got my Compact Flash mounted as EXT4. When I power up and I try and do a:
e2fsck -pv /dev/sda1
It tells me my e2fsck does not support EXT4 and to update.
How do I do that ?
I see the latest version of e2fsprogs is 1.41.12 and the current uClinux-dist has 1.40.9 and e2fsprogs-lib-1.41.0.
Thanks in advance.
You can update an app or library in uClinux-dist something like this:
Find if there are any patches/differences in the uClinux-dist version to the same version from upstream.
Put the new version next to the old version in the directory (i.e. uClinux-dist/user/appname).
Apply any patches to the new version.
Modify the top level Makefile for that app to use the new version.
Hope that it just works. ;)
Thanks - Now could you clarify how to:
I'm pretty sure I'm able to do the rest.
I've been trying to do a ./update yesterday and today and I keep getting
sopc.et.ntust.edu.tw[0: 140.118.20.145]: errno=Connection timed out
fatal: unable to connect a socket (Connection timed out)
for everything ...
--- Quote Start ---
--- Quote End ---
I've just downloaded the upstream version and did a diff. I suppose the information should be in the git history, but that depends on how the code was imported. For example:
git log -p user/portmap/portmap_6.0
shows 2 patches: the initial import of version 6.0, and the uClinux-dist patch that added the NOMMU macro and broke it.
I'm getting an error when I "make"
make[5]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user/e2fsprogs/build-e2fsprogs-1.41.12/intl'
make[5]: Entering directory `/home/janet/nios2-linux/uClinux-dist/user/e2fsprogs/build-e2fsprogs-1.41.12/intl'
make[5]: Nothing to be done for `install-shlibs'.
making install in e2fsck
make[5]: Entering directory `/home/janet/nios2-linux/uClinux-dist/user/e2fsprogs/build-e2fsprogs-1.41.12/e2fsck'
CC ../../e2fsprogs-1.41.12/e2fsck/util.c
MKINSTALLDIRS //sbin /usr/share/man/man8
GEN /home/janet/nios2-linux/uClinux-dist/user/busybox/build-busybox/Makefile
Using /home/janet/nios2-linux/uClinux-dist/user/busybox/busybox as source for busybox
LD e2fsck
e2fsck.elf2flt(.text+0x12afc): In function `init_resource_track':
../../e2fsprogs-1.41.12/e2fsck/util.c:293: undefined reference to `sbrk'
e2fsck.elf2flt(.text+0x12c34): In function `print_resource_track':
../../e2fsprogs-1.41.12/e2fsck/util.c:358: undefined reference to `sbrk'
collect2: ld returned 1 exit status
make[5]: *** [e2fsck] Error 1
make[5]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user/e2fsprogs/build-e2fsprogs-1.41.12/e2fsck'
make[4]: *** [install-progs-recursive] Error 1
make[4]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user/e2fsprogs/build-e2fsprogs-1.41.12'
make[3]: *** [all] Error 2
make[3]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user/e2fsprogs'
make[2]: *** [e2fsprogs] Error 2
make[2]: *** Waiting for unfinished jobs....
make[4]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user/busybox/build-busybox'
make[3]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user/busybox'
make[2]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user'
make: *** [subdirs] Error 1
[janet@localhost uClinux-dist]$
How can I get "sbrk" linked correctly ?
Thanks in advance
The e2fsprogs-1.41.12 is available in trunk branch which we used for mmu,
Just update the makefile to include fsck.ext4 etc.
uClinux-dist/user/e2fsprogs/Makefile
I still have the error. Here are the steps I took
From uClinux-dist directory
e2fsprogs-1.41.12
1. make clean (to start fresh)
2. put the new folder -- e2fsprogs-1.41.12 under user/e2fsprogs
3. modified the Makefile as instructed.
4. make menuconfig - defaulting everything
5. make vendor_hwselect SYSPTF=my.ptf
6. make
ALL WORKS
7. make menuconfig - (selected to customize Application/Library settings)
under Filesystem Application - EXT2 - selected "e2fsck"
8. make
AND I get the same error posted earlier. So what am I missing ?
Thanks in advance
