Use of timer in Nios
I have beginner level question about using timer in Nios. In timer datasheet there is an example:# include "nios.h"
int main(void)
int t = 0;
// Set timer for 1 second
na_timer1->np_timerperiodl = (short)(nasys_clock_freq & 0x0000ffff);
na_timer1->np_timerperiodh = (short)((nasys_clock_freq >> 16) & 0x0000ffff);
// Set timer running, looping, no interrupts
na_timer1->np_timercontrol = np_timercontrol_start_mask + np_timercontrol_cont_mask;
// Poll timer forever, print once per second
while(1)
if(na_timer1->np_timerstatus & np_timerstatus_to_mask)
printf("A second passed! (%d)\n",t++);
// Clear the to (timeout) bit
na_timer1->np_timerstatus = 0; // (any value)
When i compile and run this it works fine. But in my own application i nee timer that counts 455us not to 1 s. and i tried to change timerperiod register values. Th way I understood, they have used timer period of 33.333.000 in nasys_clock freq, which gives a time of 1 s. When i try to change it for example 15167 which is approx. 455us, there is a compiler error which says "parse error before '=' at the lines where i try to change the timer value. I tried it with the same timer example but with the different value:
# include "nios.h"# define count_time = 15167
int main(void)
int t = 0;
na_timer1->np_timerperiodl = (short)(count_time & 0x0000ffff);
na_timer1->np_timerperiodh = (short)((count_time >> 16) & 0x0000ffff);
while(1)
It suddenly doesnt work? What's the problem?
Thanks!
-jarkko
Hi jarkko,
> What's the problem?
-# define count_time = 15167
+# define count_time 15167
--Scott
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/dry.gif ehhhh.... thanks!
-jarkko
