12748 Discussions
Using HPS in Quartus 15.0 generates false output
Hello everyone,
I'm developing a project on Arria V SoC Development Kit using HPS and FPGA, it means I have to create a project in Quartus using QSYS.
I have tested my design on FPGA and it worked fine. I got the correct signal on FMCA pinout. But I want to include HPS in my design for configuration and I/O purpose from Linux.
After I created a project in Qsys with my design on FPGA as an IP with AXI interfaces included,
the output became false.
Is there anyone who has done a similar project using IP with AXI interface and HPS? Can you refer me to some tutorial? I have found very few tutorials that explains how to do what I want.
Because I tested my IP before on FPGA, I'm sure it works fine. So the problem is when I built the project using Qsys and HPS.
This project is quite important and I would really like to make it work.
Any suggestion is welcome. Thank you so much.
