Using NIOS II with DE2
Hello I am new to the DE2 and using it for my senior design project. I tried running the "hello_world" tutorial from NIOS II on the DE2 board with no success.
Is there something I did wrong or are there any .sof, .ptf and C/C++ files anyone can send me to use a starting template for the DE2?
Can you be more specific about what went wrong? The DE2 system cd has pretty much everything you need to get started with the board.
--- Quote Start ---
originally posted by benway@Feb 14 2007, 01:04 PM
can you be more specific about what went wrong?  the de2 system cd has pretty much everything you need to get started with the board.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=21566)
--- quote end ---
--- Quote End ---
I tried running the "hello_world" tutorial from NIOS II IDE on the DE2 board,
and got the following message:
"Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Pausing target processor: not responding.
Resetting and trying again: FAILED
Leaving target processor paused "
--- Quote Start ---
originally posted by kofinator+feb 14 2007, 10:24 pm--><div class='quotetop'>quote (kofinator @ feb 14 2007, 10:24 pm)</div>
--- quote start ---
<!--quotebegin-benway@Feb 14 2007, 01:04 PM
--- quote end ---
--- Quote End ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=21570)</div>
[/b]
--- Quote End ---
Is your design passing the Timing Analyser ??
What is the clock speed of your nios processor ?
