V1.4 with NiosII 5.1 problems
Hi, I am new to this stuff but here is the problem:
On fresh computer:
1) installed Quartus 5.1 Web Edition
2) installed Kit: Nios II Evaluation Edition, Version: 5.1, Build: 73b
3) installed nios2linux-1.4.zip
During nios2linux-1.4.zip install strange message box appear:
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
Setup
Cygwin extensions were not installed properly
Please see the README for instructions on how to install them manually[/b]
--- Quote End ---
What does it mean? I didn&#39;t find anything about cygwin neither in readme nor in other documentation files.
After that I follow Linux Quick Start Guide but at step &#39;Creating Kernel Project&#39;
&#39;New Project&#39; dialog doesn&#39;t contain "Microtronix Nios II" folder with kernel project.
Any idea where to dig and what to read to get started?
You can try running the script : ./install_cyg_ext.sh
But be aware though that while all worked with 5.0, version 5.1 created a problem with the "upload" command, so you won&#39;t be able to complete the installation of the Kernel on your board as indicated in the Quick Start Guide...
Hope this helps,
Bert
