12748 Discussions
VHDL modulo operator causes "Nios Verify failed" - But why?
I have curious problem...
In my design I have a TSE which is feed by my own VHDL logic. Further there is a Nios which configures TSE. That's it.
Everything works fine. BUT, when adding a modulo operation like
a := b mod c;
Eclipse says "Verify failed between address 0x40000 and 0x4FFFF" during programming. When removing and replacing this modulo operation with simple logic, everything works fine again.
I can't understand this, because my own VHDL logic has now memory mapped interface. So there isn't any relationship between my own VHDL logic and the OnChip-Memory 0x40000 to 0x4FFFF.
Does anybody has any idea???
Thanks for really every hint...
the mod operator synthesises to a very complicated circuit, and with what you are doing it is attemting to compute the result in 1 clock cycle. Im guessing that because of this, it cannot generate "a" in time, and so whatever "a" drives is wrong.
Did you configure Timequest correctly with your timing constraints? I agree with Tricky that the complexity of this operator probably synthesize in logic that is too slow, but Timequest should have spotted this.
