VIP lcd demo
Hello there!
I am trying to run the demonstration I downloaded from there:
http://www.nioswiki.com/Nios2EmbeddedEvaluationKit/Altera's_Video_and_Image_Processing_Suite_Demo_on_the_NEEK
I cannot say it does not work, actually it does something. However, there is absolutely
no interactivity with the source code provided.
In the main.c, there is a loop which (I suppose) should provide some interactivity.
But this loop is never reached.
When I set breakpoints, I can go step by step until Mixer_init();
This starts the video display, but that's the last function I can step over.
If I try to step into one of the functions after this line, the debugger seems to be
lost.
Basically what I would like to do first is:
- Have some interactivity (draw menus, etc), and have actions caused by these menus;
- Grab a frame's data buffer;
- Do some processing on it.
Some questions:
- What is the minimal configuration? If I comment out the lines Clipper_init() or
Scaler_init() that are before Mixer_init(), then the image does not show. But I don't need
a scaler and a clipper.
- Is there some free IP with full source code around? For instance showing hot to
get an interrupt, read a frame from some memory buffer, return a pointer to it, etc,
working on NIOS? The problem with the prebuilt elements is that there is no access
to the source code. I would be happy to know for instance, what is in Mixer_init().
Well, I know that it's a wrapper function managing an object, but I would like to know
what exactly happens in the object itself.
By the way, could somebody at Altera filter the irrelevant comments at this link:
Pascal
I downloaded and modified this one (http://www.nioswiki.com/@api/deki/files/421/=neek_vip_demo_lcd_svga_v91_2.zip) (it doesn't compile out of the box, but the fixes are really simple)...comes with source. As far as the debug behavior you describe, that's caused by optimization. "-O0" is what you want to use.
Cheers,
-slacker
Hello!
Thanks for your reply!
I downloaded the same one. Actually it was the program I was already using.
It compiles out of the box in my case, but the image is swept by an horizontal
line a few times, then the top blue band is replaced by a white band, then after
a while the image disappears completely and is replaced by a color pattern (the
image is split horizontally, the top half is a gradient from blue to lime green,
and the bottom part is a gradation from red to yellow).
Now I'm not sure how to set the option -O0. I right-clicked the project, went
to properties -> C/C++ build and added -O0 (minus capital-O zero) in the
field "compiler invocation command". Is this right?
Anyway it does not change anything, I still cannot enter the functions I want to
jump into (at least after the mixer is started).
By the way, I am using quartus 9.1 sp2 and NIOS 9.1 IDE. Both were downloaded
at the same time, so I guess they fit.
Now I have rebuilt the same program from scratch (as you tell me it works fine),
but I get the same result as before: no interactivity at all.
Could you describe how your program works?
As for mine, the image (roughly 640 x 480) is centered and it displays live video.
The top margin (from the top of the screen to the top of the picture) has been replaced
by a blue rectangle. That's it. No interaction although the touch panel is enabled.
It never enters the while loop. As there are issues with the debugger, I print a marker
everytime the loop is entered, but nothing is printed on the console, so the loop is not
reached. Any idea?
Pascal
