Sorry if this is a basic question, but I couldn't find an answer in the literature or forum.
I've implemented a VIC in the SOPC Builder, but after generation I now have a d_irq_to_the_cpu_0 input. What is this input used for? Is it an enable?Link Copied
Has no one ever used the Vector Interrupt Controller? What is this input used for? Any ideas?
Did you follow the AN? -- http://www.altera.com/literature/an/an595.pdf
In my work, I've never seen that signal exported to the top so you must be doing something...unique. :-) Cheers, - slacker- Mark as New
Thanks very much for the response. Yes, I've seen the AN595, and used it to setup the VIC in the SOPC builder, though I haven't read it in its entirety.
Based on your response though, I would assume that I'm doing something...unique.:) If I find out what that is, I'll post it here. In the meantime, if anyone else knows what this input is for I'd appreciate any info. Thanks.- Mark as New
Well it seems I was doing something unique, and I thought I'd share. After speaking with Altera customer support, I received the following solution:
--- Quote Start --- Good news… I found the root caused for this issue, the d_irq_to_the_cpu_o port will generated when the VIC is connected to output clock from PLL core instead of ALTPLL. Please see attachment for more information. Workaround: Use ALTPLL in SOPC Builder. http://www.altera.com/literature/hb/nios2/n2cpu_nii53002.pdf This issue might be VIC bug; I will submit the bug report for our R&D team to deep investigation. Thanks for bringing this to our attention and I sincerely hope that we may serve in more convenient way in the future. --- Quote End --- After this fix, the project wouldn't compile correctly with a handful of errors similar to: --- Quote Start --- Error: PLL "pll" uses test only parameter c0_test_source, but parameter must only be used in test mode --- Quote End --- After speaking with customer service again, I received an additional solution which allows me to compile correctly: --- Quote Start --- I tried to debug this issue, and below were the methods: 1. Remove PLL in SOPC, regenerate, update symbol, recompile: failed 2. Remove PLL & ALTPLL in SOPC, regenerate, update symbol, recompile: passed 3. From Step2, Insert the altpll megafunction on the top level, and connect the output clock to SOPC symbol block: Passed (archieve project attached) 4. Add back the ALTPLL in SOPC from step 3, regenerate, update symbol, recompile: Failed 5. Also, I tried to create a new project in Quartus II with the same components as your project, and regenerate & recompile: Passed I suspected this issue is created by the old PLL with ALTPLL in a SOPC project. --- Quote End ---- Mark as New
I have the same problem. Can I just ignore this input port or will VIC not function properly?
