公告
12748 讨论
Verify problem while runing on Nios II hardware
名誉分销商 II
2,006 次查看
Hi there,
when i try to run my project on the Nios II hardware i get the following problem:
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Processor is already paused
Reading System ID at address 0x00070000: verified
Initializing CPU cache (if present)
OK
Downloading 00080000 ( 0%)
Downloaded 43KB in 0.7s (61.4KB/s)
Verifying 00080000 ( 0%)
Verify failed between address 0x80000 and 0x8ABDF
Leaving target processor paused
I use the SRAM memory on DE1 board which has the Cyclone II FPGA. I also checked the base and end address for SRAM, and there is also no overlaping. The SRAM memory has the base address 00080000 and 0008ffff end address. I also use the on-chip memory for better perfomance.
Have anyone an idea how to fix that problem?
Best regards!
0 项奖励
5 回复数
名誉分销商 II
656 次查看
Please check the Vector and Exception address are Pointing to?
Which QII verison are you using.
0 项奖励
名誉分销商 II
656 次查看
This problem may arise due to wrong pin assignment of an SRAM, so just check the pin assignment if any mistake is there.
0 项奖励
名誉分销商 II
656 次查看
Check for proper pin assignment of -
1. Clock
2. Reset
Also check in 'system library properties' that you are using on chip memory, and not sram, as program memory
0 项奖励
名誉分销商 II
656 次查看
It's happened to me once or twice because I forgot to use bidir pins for the data lines.
0 项奖励
名誉分销商 II
656 次查看
Thanks to all for your suggestions! I checked the pin assignment and it's perfect,there aren't problems. Also, the sys_lib is OK, I choose the SRAM memory as place for my code. The clock signal has the appropriate pin.
I fixed the problem, it was my mistake because I set the data bus as only output direction and now I use it as bidirectional direction and it works. Sometimes we have to look for the simpliest causes :rolleyes:. Before i fixed the problem I tried many options. Jakobjones gave me very good suggestions.
Again, thanks to all, Lightline you was right and if I wouldn't fix it before your
suggestion were good!
Best regards!
0 项奖励
回复
