12745 Discussions
Verilog Program - Need help with it
Hello all,
I have no clue about Verilog and I want to understand a bit of program that might be useful to me. Would you happen to know what this means? I am trying to convert that into VHDL. I guess module is entity, wire is signal and the ports are inputs and outputs but what does the rest of the program mean?
`define rom_size 6'd8
module CLOCK_500 (
CLOCK,
CLOCK_500,
DATA,
END,
RESET,
GO,
CLOCK_2
input CLOCK;
input END;
input RESET;
output CLOCK_500;
output [23:0]DATA;
output GO;
output CLOCK_2;
reg [10:0]COUNTER_500;
wire CLOCK_500=COUNTER_500[9];
wire CLOCK_2=COUNTER_500[1];
reg [15:0]ROM[`rom_size:0];
reg [15:0]DATA_A;
reg [5:0]address;
wire [23:0]DATA={8'h34,DATA_A};
wire GO =((address <= `rom_size) && (END==1))? COUNTER_500[10]:1;
always @(negedge RESET or posedge END) begin
if (!RESET) address=0;
else
if (address <= `rom_size) address=address+1;
end
reg [7:0]vol;
always @(posedge RESET) begin
vol=vol-1;end
always @(posedge END) begin
// ROM[0]= 16'h1e00;
ROM[0]= 16'h0c00; //power down
ROM[1]= 16'h0ec2; //master
ROM[2]= 16'h0838; //sound select
ROM[3]= 16'h1000; //mclk
ROM[4]= 16'h0017; //
ROM[5]= 16'h0217; //
ROM[6]= {8'h04,1'b0,vol[6:0]}; //
ROM[7]= {8'h06,1'b0,vol[6:0]}; //sound vol
//ROM[4]= 16'h1e00; //reset
ROM[`rom_size]= 16'h1201;//active
DATA_A=ROM[address];
end
always @(posedge CLOCK ) begin
COUNTER_500=COUNTER_500+1;
end
endmodule
The correspondences between verilog and VHDL terminology are correct.
A "module" in verilog however corresponds to both a "entity" and "architecture" combination in VHDL.
In Quartus-II you can use an instance of this module in verilog in a higher level VHDL description. It is easy to mix VHDL and verilog.
CLOCK_2 is a half frequency CLOCK.
GO is the 1/2048 frequency CLOCK when END is high and address is in desired region. Else , GO is high.
When END assert, the ROM read out its next data to DATA[15:0] port.
The DATA[23:16] stuck at 8'h34.
And the ROM initial value is:
Ok,
So if I want to write this in VHDL? How would I do it? Should I assign values the same values for ROM in VHDL terms?
Well I had a longer answer here but the forum didn't save it.....
With an HDL file open in Quartus try "Edit" --> "Insert Template" and you'll find to code fragments you can use. Here is a good document as well: http://www.altera.com/literature/hb/qts/qts_qii51007.pdf
So, would that part translate to:
signal ROM : rom_type;
After the begin of architecture
ROM(0)<=X"0c00";
ROM(1)<=X"0ec2";
ROM(2)<=X"0838";
ROM(3)<=X"1000"
ROM(4)<=X"0017"
ROM(5)<=X"0217"
ROM(6)<=X"04" & '0' & vol(6 downto 0);
ROM(7)<=X"06" & '0' & vol(6 downto 0);
Also, how would the following part convert, am I doing it right?
VERILOG:
else
VHDL:
process(clk) begin
if rising_edge(clk) then
if reset = '1' then
address <= '0';
elsif
address <=rom_size;
end if;
"if (address <= `rom_size) address=address+1;"
I consider this sentence as that address plus one only when value of address less than or eq. to the value of rom_size. Not actualy a non-blocking assignment.
Except this point, I think you translate well.
P.S. I'm not a professional HDL writer. XD
And the original verilog implemented in some asynchronous approach.
verilog:always @(negedge RESET or posedge END) begin
your VHDL: process(clk) begin
If you want to synchronize with 'clk', it would be better to sample the 'END' signal first, and then you could finish the remaining part by using the sampled signal.
