12747 Discussions
Very simple question about PIO
typedef volatile struct
int np_piodata; // read/write, up to 32 bits
int np_piodirection; // write/readable, up to 32 bits, 1->output bit
int np_piointerruptmask; // write/readable, up to 32 bits, 1->enable interrupt
int np_pioedgecapture; // read, up to 32 bits, cleared by any write
} np_pio;
can you explain me how to use PIO register...for example if i want to read
a pio register... i do PIO->np_piodata..
Why does the function of " np_piodirection"
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ph34r.gif http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ph34r.gif http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ph34r.gif http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ph34r.gif
in general if you want learn something about the peripherials, you might want to read "Altera Embeeded Peripherals Handbook" (n2cpu_nii5v3.pdf).
However you should use inl(...) for reading and outl(...) for writing the hardware register.
Accessing the hardware register with such a structure is a "Nios speciality".
