12745 Discussions
What is cpuresetrequest_to_the_cpu
The sopc builder generates a simple niosii model,but i donot know why there are the two pins ,marked 'cpuresetrequest_to_the_cpu' and 'cpuresettaken_from_the_cpu'?
You can use those pins, one for RESET CPU, one for RESET INDICATOR
They can be connected to other vhdl blocks to force the nios cpu into a reset state (it keeps reading the first instruction from the reset vector, but decides not to execute it), and to find out whether the cpu is in reset (pulsed active for one clock - probably when the execution is aborted).
To be useful the 'reset taken' line needs latching and masking with 'reset request'.
Search for "cpu_resetrequest" in this document: http://www.altera.com/literature/hb/nios2/n2cpu_nii51002.pdf
