I want to add ftp service in nios2 with DE II board, so I read the documention --Adding User Applications to the uClinux Distribution, I find there may have the config folder in uClinux-dist-test, but now, in my system, under uClinux-dist-test folder, there have "COPYING , freeswan , lib , Makefile, README , tools , user, Documentation , include, linux-2.6.x ,openswan,SOURCE ,uClibc ,vendors", I couldn't do my work now?
how could Ito no next? THXLink Copied
--- Quote Start --- originally posted by goral@Apr 14 2006, 03:01 PM i want to add ftp service in nios2 with de ii board, so i read the documention --adding user applications to the uclinux distribution, i find there may have the config folder in uclinux-dist-test, but now, in my system, under uclinux-dist-test folder, there have "copying , freeswan , lib , makefile, readme , tools , user, documentation , include, linux-2.6.x ,openswan,source ,uclibc ,vendors", i couldn't do my work now?
how could ito no next?
thx
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14362)
--- quote end ---
--- Quote End --- Please use ~/apps/ftpd
cd ~/apps/inetd
make
make install
cd ~/apps/ftpd
make
make install
echo "ftp stream tcp nowait root /bin/ftpd" >>~/rootfs/etc/inetd.conf
rebuild zImage for initramfs, boot nios uclinux, and run, inetd&
Thanks for your suggestion, I make and generate zImage, and then download it in my board, when I typed inetd&, 30 was appear in terminal screen, why?
Ok, I see!
But I have another question, the Usr name and Password how to get?- Mark as New
--- Quote Start --- originally posted by goral@Apr 14 2006, 03:47 PM ok, i see!
but i have another question, the usr name and password how to get?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14366)
--- quote end ---
--- Quote End --- You have to read "man ftpd" . And some google search like "how to setup ftpd" .
to use anonymous ftp user,
add "ftp:x:14:50:FTP User:/home/ftp:" to etc/passwd add "ftp:x:50:" to etc/group make dir home/ftp add ftp contents to home/ftp- Mark as New
thx
--- quote end ---
--- Quote End --- for uClinux-dist-test, you should remove the old dir, look at the build script and untar, patch.
THX for your reply!
Now I can using FTP service now! Thanks for your help! --- Quote Start --- originally posted by hippo+apr 14 2006, 09:31 pm--><div class='quotetop'>quote (hippo @ apr 14 2006, 09:31 pm)</div>--- quote start ---
<!--quotebegin-goral@Apr 14 2006, 03:01 PM i want to add ftp service in nios2 with de ii board, so i read the documention --adding user applications to the uclinux distribution, i find there may have the config folder in uclinux-dist-test, but now, in my system, under uclinux-dist-test folder, there have "copying , freeswan , lib , makefile, readme , tools , user, documentation , include, linux-2.6.x ,openswan,source ,uclibc ,vendors", i couldn't do my work now?
thx
--- quote end ---
--- Quote End --- for uClinux-dist-test, you should remove the old dir, look at the build script and untar, patch. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14374)</div> [/b] --- Quote End ---
