12745 Discussions
Not found rc file in ~/rootfs/etc dir
hello all
I want to edit rc file before rebuild kernel that can't find rc file in ~/root/etc dir.
I don't like to excute "ifconfig" or "inetd" command every time under the uClinux.
Can i add a rc file in ~/root/etc dir?
On uClinux : ~/bin/login
I don't know uClibic login's account and "Password".
How to know my account and password ?
Because I don't login to use my uClinux OS every time . so , i want to creat it..
How to creat a account on uClinux OS?
Thanks in advance !
jay
--- Quote Start ---
originally posted by jay_1025@Apr 14 2006, 07:21 PM
hello all
i want to edit rc file before rebuild kernel that can't find rc file in ~/root/etc dir.
i don't like to  excute "ifconfig" or "inetd" command every time under the uclinux.
can i add a rc file in ~/root/etc dir?
on uclinux : ~/bin/login
i don't know uclibic login's account and "password".
how to know my account and password ?
because i don't login to use my uclinux os every time . so , i want to creat it..
how to creat a account on uclinux os?
thanks in advance !
jay
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14369)
--- quote end ---
--- Quote End ---
There are many ways to add init tasks.
you can add simple init command into etc/inittab, just like the lo init.
you can add a line in inittab to run etc/rc .
you can uncomment the line contains /etc/init.d/rcS in inittab .
then ~/rootfs/etc/init.d/rcS will be executed during linux init.
the default rcS will run each Sxxxxxx task.
the account and passwd file are etc/passwd and etc/shadow .
the simple inittab from ~/download, does not use login, it call /bin/sh directly.
Hi hippo
I have edit "inittab" file in ~/rootfs/etc and recompile kernel .
But not update the initramfs....
compile kernel info:
perl -I/home/jay/linux-2.6.16.1/arch/nios2nommu/scripts /home/jay/linux-2.6.16.1/arch/nios2nommu/scripts/gen_nios2_system.h.pl cpu_0 sdram_0 cfi_flash_0 < nios_0.ptf > include/nios2_system.h.tmp; if [ -r include/nios2_system.h ] && cmp -s include/nios2_system.h include/nios2_system.h.tmp; then rm -f include/nios2_system.h.tmp; else echo &#39; UPD include/nios2_system.h&#39;; mv -f include/nios2_system.h.tmp include/nios2_system.h; fi
CHK include/linux/version.h
CHK include/linux/compile.h
CHK usr/initramfs_list
Kernel: arch/nios2nommu/boot/zImage is ready
I don&#39;t see the "GPIO" and "GZIP" in compile messages and not find "initramfs_list" file in ~/rootfs/usr/ dir.
THx
hi hippo
This is booting message:
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
setup_arch: No persistant network settings signature at 008F0000
Built 1 zonelists
Kernel command line:
PID hash table entries: 64 (order: 6, 1024 bytes)
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory available: 6072k/8192k RAM, 0k/0k ROM (1402k kernel code, 623k data
Mount-cache hash table entries: 512
NET: Registered protocol family 16
io scheduler noop registered
io scheduler deadline registered (default)
Serial: JTAG UART driver $Revision: 1.4 $
ttyJ0 at MMIO 0x81004000 (irq = 1) is a jtag_uart
dmfe_probe:eth0, 50000 Khz Nios
<DM9000> eth0 I/O: 80900090, VID: 90000a46
ADDR: 00:07:ed:00:00:00
dmfe_probe:eth1, 50000 Khz Nios
NET: Registered protocol family 2
IP route cache hash table entries: 128 (order: -3, 512 bytes)
TCP established hash table entries: 512 (order: -1, 2048 bytes)
TCP bind hash table entries: 512 (order: -1, 2048 bytes)
TCP: Hash tables configured (established 512 bind 512)
TCP reno registered
TCP bic registered
NET: Registered protocol family 10
IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
Freeing unused kernel memory: 508k freed (0x16e000 - 0x1ec000)
init started: BusyBox v1.1.1-pre0 (2006.04.14-14:34+0000) multi-call bina
Bummer, could not run &#39;/bin/ifconfig&#39;: No such file or directory
BusyBox v1.1.1-pre0 (2006.04.14-14:34+0000) Built-in shell (msh)
Enter &#39;help&#39; for a list of built-in commands.
# ps
PID Uid VmSize Stat Command
1 root DW init
2 root SWN [ksoftirqd/0]
3 root SW< [events/0]
4 root SW< [khelper]
5 root SW< [kthread]
6 root SW< [kblockd/0]
7 root SW [pdflush]
8 root SW [pdflush]
10 root SW< [aio/0]
9 root SW [kswapd0]
22 root Z [inetd]
25 root SW /bin/boa
32 root SW init
33 root SW /bin/sh
34 root RW ps
I have add "/sbin/ifconfig eth0 xxx.xxx.xxx.xxx" line in ~/rootfs/etc/inittab file and rebuild kernel.
Why not to update the kernel?........... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
Thanks in advance !
jay
--- Quote Start ---
originally posted by jay_1025@Apr 15 2006, 01:19 AM
hi hippo
i have edit "inittab" file in ~/rootfs/etc and recompile kernel .
but not update the initramfs....
perl -i/home/jay/linux-2.6.16.1/arch/nios2nommu/scripts /home/jay/linux-2.6.16.1/arch/nios2nommu/scripts/gen_nios2_system.h.pl cpu_0 sdram_0 cfi_flash_0 < nios_0.ptf > include/nios2_system.h.tmp; if [ -r include/nios2_system.h ] && cmp -s include/nios2_system.h include/nios2_system.h.tmp; then rm -f include/nios2_system.h.tmp; else echo &#39;  upd  include/nios2_system.h&#39;; mv -f include/nios2_system.h.tmp include/nios2_system.h; fi
  chk  include/linux/version.h
  chk  include/linux/compile.h
  chk  usr/initramfs_list
kernel: arch/nios2nommu/boot/zimage is ready
i don&#39;t see the "gpio" and "gzip" in compile messages and not find "initramfs_list" file in ~/rootfs/usr/ dir.
thx
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14384)
--- quote end ---
--- Quote End ---
the file is in kernel dir, ~/linux-2.6.x/usr/initramfs_list
hi hppo
My Kernel can update now....
Thak you!!
