12748 讨论
Why Nios II Simple Socket Server design example terminal stop before mapping PHY to tse_mac_device
Workharder
初学者
1,146 次查看
 I programed the provided file via JTAG and then ran Nios2-terminal.exe, but the terminal hangs in the middle of the process.  See image below.  Because the terminal hangs, I hit control-c to cancel the terminal.  If I then attempt to rerun “Nios2-terminal.exe”, the terminal appears to remain hung from the previous attempt.
"INFO: PHY[0.0] - Automatically mapped to tse_mac_device[0]"
message doesn't come up.
0 项奖励
4 回复数
KellyJialin_Goh
1,129 次查看
Greetings and welcome to Intel's Forum.
1) May I know the Simple Socket Server design example that you are using? Could you kindly attach the link here.
2) May I also know the Quartus version you are using for your Simple Socket Server example? As there are some version of Quartus that does not support the simple socket server design.
3) I have here a KDB that might be related to your issue for your reference: https://www.intel.com/content/www/us/en/support/programmable/articles/000086010.html
4) You may also refer to the user guide for more information to interact with the Simple Socket Server on NIOS II console: https://www.intel.com/content/www/us/en/docs/programmable/683574/21-3/interacting-with-the-nios-ii-simple.html
Hope this information helps. Thank you.
Kelly
0 项奖励
KellyJialin_Goh
1,088 次查看
Any updates from your end whether the feedback provided was useful?
Hope to hear from you so to understand more regarding the issue you are facing.
Thank you.
Kelly
0 项奖励
KellyJialin_Goh
1,068 次查看
Are there any further help needed from my end? Were the feedback provided useful to you?
Thank you.
Kelly
0 项奖励
KellyJialin_Goh
1,049 次查看
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
Thank you.
Kelly Jialin, GOH
0 项奖励
回复
