12748 Discussions
Why does ROMRAM ECOS not initialize ICache of NIOS
Please refer to NIOS II vector.s file. Why does NIOS II ROMRAM application not initialize NIOS II I-Cache?
* _hardware_reset
* This is the reset entry point for Nios II.
* At reset, only the cache line which contain the reset vector is
* initialized. Therefore the code within the first cache line is required
* to initialize the instruction cache for the remainder of the code.
* Note that the automatically generated linker script requires that
* the .init section is less than 0x20 bytes long.
.section .entry, "xa"
.align 2
* Some tools want to know where the reset vector is.
.globl _hardware_reset
* Explicitly allow the use of r1 (the assembler temporary register)
* within this code. This register is normally reserved for the use of
* the compiler.
.set noat
# ifdef CYG_HAL_STARTUP_ROM
_hardware_reset:
/* Initialize all cache lines within the instruction cache */
# if NIOS2_ICACHE_SIZE > 0
* The assumption here is that the instruction cache size is always
* a power of two.
# if NIOS2_ICACHE_SIZE > 0x8000
movhi r1, %hi(NIOS2_ICACHE_SIZE)# else
movui r1, NIOS2_ICACHE_SIZE# endif
movui r2, NIOS2_ICACHE_LINE_SIZE
0:
initi r1
sub r1, r1, r2
bgt r1, zero, 0b# endif /* NIOS2_ICACHE_SIZE > 0 */
* Having initialised the cache, call the entry point for the .text
* section.
movhi r1, %hiadj(_start)
addi r1, r1, %lo(_start)
jmp r1# endif /* CYG_HAL_STARTUP_ROM */
