12748 Discussions
Why there is no response for my app on uclinux
I manage to make my code running on uclinux, but there is no response.
just as follow:
/>./test.bflt
why does this happen?
I build it on nios IDE for windows, and use
# nios2-linux-uclibc-elf2flt test -R test.o
to convert it to flat format. And got an error, reloc outside, then
# nios2-linux-uclibc-flthdr -r test.bflt
upload using ftp client in uclinux and run with no response?
Is there some suggestion?
thx
I think if it did not run you would get an error stating that it was not an executable or something like that?
What kind of output does it normally have?
--- Quote Start ---
originally posted by hippo@Jul 26 2006, 10:19 PM
see the wiki,
http://nioswiki.jot.com/wikihome/operating...ms/compilehello (http://nioswiki.jot.com/wikihome/operatingsystems/compilehello
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17137)
--- quote end ---
--- Quote End ---
I want to port a C++ program to uclinux. But I can&#39;t find a way to compile it using the toolchain under linux.
Could you suggest a clue?
--- Quote Start ---
originally posted by spaceli+jul 27 2006, 11:20 am--><div class='quotetop'>quote (spaceli @ jul 27 2006, 11:20 am)</div>
--- quote start ---
<!--quotebegin-hippo@Jul 26 2006, 10:19 PM
see the wiki,
--- quote end ---
--- Quote End ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17162)</div>
[/b]
--- Quote End ---
The libstdc++, which I built with buildroot, still has problem to run.
Microtronix sell a linux toolchain with C++ support .
yeah, it seems NIOS2 IDE has stdlibc++, I compile it and use elf2flt to convert it to flat format. but it couldn&#39;t work. Sometimes it tell me reloc outside, sometimes no response. So I get confuse. Maybe CDK from Microtronix could help.
thx for your clue.
So there is no perfect way (of course for free-fee) to make a C++ toolchain,
is it?
By the way, does elf2flt -r means to run with out load?
I&#39;m confuse about the parameters in elf2flt.
And someone said elf2flt just strips the symbol and debug info from elf and make the header simple, is that right?
1. the libstdc++ in IDE is for newlib, it can not run in uClinux.
2. the elf2flt needs several steps, and there are some variation between arch.
for nios2, you should use -elf2flt flag for linkage.
it is difficult to use elf2flt and flthdr alone.
3. it is possible to work out c++ with buildroot. The c++ is compiled and linked, but crashed after c++ func calls. ( I am not a c++ user, I can&#39;t fix the problem. ) .
the tools from Microtronix costs $900, but I think it should be based on buildroot and should be GPL?
