Working with Nios II and SDK
I make a new design and are going to use legacy SDK in conjuction with a Cyclone II (2C20Q240). The main reason is to use Plugs instead of LWIP and RTOS.
I want to flash my executable Nios code. But there seems no tool available from altera. I tried elf2flash, but it doesn''t work.
Has anybody an idea how it can be done?
Hi Minu,
> from altera.
Use nios2-flash-programmer.
Please be more specific.
Yes, elf2flash and nios2-flash-programmer. You should review the documentation.
--Scott
Hi Scott,
after posting my message I grubbed more in the altera documentation.
First it seemed I do not have success. I could not download the .flash-files. I took the USB-Blaster instead of the ByteBlasterMV. After that I could download the .flash-files.
I made some tests with my own Quartus- and Nios-Projects and it worked!
I had to spend a couple days running this stuff on Nios SDK Shell. Because of using Plugs I inted to use Legacy SDK instead of IDE Nios II.
I am making a desing with Cyclon II 2c20Q240 FPGA (it's a new one). Now I have to wait for the Quartus version 5.1 service pack 1. I hope I will be able using the Lecacy SDK with this new versions.
Armin
